My rig has JD7 brake code with 2 1/2" brakes in the rear. Everything else is rated higher than that so I decided to upgrade to slip on drums and 3 1/2". After several days of calling wrecking yards, like about 200 of them, if they have a complete rear end they don't want to split them up, $600 to a grand complete. Funny thing tho, no one had a 'core'. Not one!!! I found out that lots of burbs have slip on drums with 2 1/2" brakes. Found a guy that does only rear ends for rock hounds, said that these are what anyone serious about crawlin' wants. He cuts them down for any chassis. Point is, had lots of brake stuff left over. I got backing plates out for 3 1/2", complete with hubs and slip on drums, both sides for $200. Gotta drive 150 miles to get them. Guy says he has several drums so I can pick the best pair. Might even find a set of good shoes, just nervous about mix match on the shoes tho. Riding on 5500 lb. "E" rated tires so should be good to go.
Gonna replace the flex hoses while I'm at it, I figure to just put stock ones on. What's there went 18 years and a quarter mil miles so good nuf.
