Early ABS was quite frankly experimental. :rof:
1992 4 wheel ABS on an Olds Bravada would scare you by just letting the brakes off. I bent the brake pedal on one with the ABS unit fighting me.
RWAL has been quite nice to stop rear wheel skids and keep you straight. I have always liked this from the start esp when unloaded.
1995+ Yukons and Suburbans IMO are more of a decent and useable system.
I was reminded the other day to pump the brakes when an old full size van started to go sideways on me - A skill you forget with modern ABS.
Here is the proportioning valve info for suburbans.
http://www.thetruckstop.us/forum/showthread.php?14050-Brake-proportioning-valve
Here is a valve failure like I had.
http://www.thetruckstop.us/forum/showthread.php?14105-combination-proportioning-valve
