I am looking for suggestions with my current setup - nothing more and no slight made or implied to A-team or my tuner.
1995 suburban is literally a mosquito fogger. Black smoke on acceleration that clears up to a medium black. Smokes like a NA 6.2 climbing the Eisenhower tunnel. Recall the thread where this failed emissions so badly that it passed as it sooted up the smoke sensor to failure... It is like the EGR I don't have is stuck open.
I get black smoke at anything but the lightest of throttle. Runs good and pulls strong to the redline.
This is a non-standard A-Team install. I am using 6.2 heads and the higher 6.2 compression along with 6.2 military precups. 4" exhaust with straight through muffler and nothing else. K47 air filter assembly. low temp t-stat, HO water pump and Kennedy low temp fan clutch with Dmax fan. Fresh injectors. new timing chain and verified timing marks. 30K or so on the used 6.2. No exhaust or intake leaks. 6000 miles on install and A-Team. Orange tube replaced with blue silicone hoses - so no boost leak there. No fender snorkel seen.
Tuner has made some changes by cutting fuel back and timing. This dropped the EGT's and smoke some. Tune runs fine in another 6.5 w/ A-Team.
EGT's climb and stop at 1210, IAT is 256 degrees on a 100 degree day with 10 Lbs boost or more seen by the MAP. 135 IAT when not on the throttle. Timing desired appears to match actual very closely if not perfectly. PMD resistor is missing or burnt out and bypassed elsewhere in harness for now. It was 100 degrees out for the above numbers.
Can't tow with it as ECT and EGT's go through the roof.
I am looking for ideas or suggestions outside of tuning just in case I have something else going on. Perhaps the 6.2 items require different tuning or will not work with this setup?
I will try the stock chip and see if it still has trouble. What else should I double check?
