buddy
Active Member
Where exactly is the PCM fuse located on the 1996 Suburban? The diagram shows you the ECMB fuse is the constant power and the ECM1 fuse is the ignition power. They are under the hood as far as I know, but I don't have any OBDII trucks to verify.
The pictured add a circuit in your link. Is it the correct size? 10 amps, 16 ga wire? They had on with 2 fuses to add 2 circuits.
Do these still yield a fused connection to the fuse they replaced? They do not add 2 circuits, one of the fuses will be the fuse you remove that protects the original circuit. For example, you take the ECM1 fuse out, plug in the "add a circuit" thing and put the ECM1 20A into the "add a circuit" bottom spot. Put a switched battery power line to the 16 ga wire and another 20A fuse in the "add a circuit" and it will work as a parallel power source. Even though its only rated for 10amps, doesnt mean its going to cook. I cannot imagine anything drawing more than 10 amps continuously, maybe just on startup, with glows and what not. I had an electric water pump that only used 5 amps and had more flow than even our HO pumps. I realized though they have regular ones and mini-fuse ones, so probably need regular sized one. Although here is another option that won't be current limited, can just use existing fuses and is also quick, clean and simple http://www.amazon.com/dp/B000CQBNFI/?tag=jhuntlink-20. You can probably find these things at autozone.
For the ground I am looking for the black wire out of the PCM plug correct or could there be more than one ground wire? The black with white stripe?
Diagram shows you the pin number and wire colors, there is black/white and tan/white, but you would probably want to pull the connector off anyway to check that the pins have good continuity to ground
Advice on stripping the wire to T in a connection. I've never liked scotch connectors because they often cut some of the wires when they are installed. Do they make something similar that works good? That doesn't present that issue?
I just use a knife and cut away a little spot of insulation and wrap and twist a wire around it, I solder if its permanent, and wrap it with electrical tape. Or you can get a butt connector, cut the wire, strip the ends, crimp one end down with one of the cut wire and the other end with the other and an extra wire, but then the butt connector has to fit two wires, if the other end wont be tight with only one wire, just strip it back far enough to fold it over.
My reply is in blue above
