ak diesel driver
6.5 driver
Well I'll find out soon enough my dad just ordered me one for about $60 and it is made in Brazil and reccommended by the wholesaler. So I will desolder mine and see what it looks like on the inside.
mine is a stock Fisher setup. I thought the setup you have is called speedcast and is cable operated no? On mine the pump only spins when I move the blade. Extra clutch wear but cheaper to replace than the pump.
Looking through the Fisher documentation (as I just put my MM1 on the other night) there was 5 pump styles for the MM1. They can be seen here - http://library.fisherplows.com/publications.asp?cat=248
Mine has the SEHP (solenoid electric hydraulic pak) For the most part, I prefer it - although belt driven sure would be nice for battery power (granted, it seems to be holding up decent so far)
My biggest complaint about the fisher plows is the trip edge. It seems to want to snag, slam, and trip all the time. I wonder if its partially because it so worn out, one side is 1" shorter than the other (someone plowed pavement with it angled all the time...) Even with the shoes on, its constantly grabbing and digging in :-(
Here are the pics of my set-up. STS truck and trailer in Syracuse, NY installed it on the truck with 25 miles on the clock back in 1994.
First pic is my truck next to my lifted '99 WJ. Sorry for the little bit of red rats nest wiring, needed to wire up the trailer brakes quick last summer and haven't touched them since.
For some of you who dont know i rebuilt my engine last year and had everything repainted. Look at the rust from only 1 winter season... Dissapointing....
So AK, where is your windshield fluid resevoir been located too?
Just like my fisher control setup.
I'd love to swap on a clutch pulley like AK has and work it all into the existing serpentine system.....![]()
