Whenever you put on a new turbo(s), you wanna give them a couple hundred miles to break in the journal bearings. If it's a water cooled, ball bearing type turbo, you can pound on it right off the bat. It's not good to do to journal bearing turbos though.
They'll be a little tight for the first 200 miles or so, but after that it's azz beatin' time.
The other thing is, I replaced the head gasket and fire rings and they need a few heat cycles to fully seat. I'll need to do a retorque on the studs at 50 and 250 miles and check the valve lash, but that's about it.
I've got 2 other big projects in the shop right now, so I won't be able to hit the dyno for a few weeks, but yeah, I'll need about 2 hours of dyno time to get it tuned in. Once it's where I want it, I'll get ahold of my buddy Brian (manages the track) and I'll get some time to dial it in on some passes.
The new wheels and tires should be here next week also, so I can stop blowing these ProComp's up in smoke.
