You fund the dyno I'll run it,
As far as mpg results, I made the same trip bi-weekly same route MS to GA/FL for nearly 3 years, before ATT with the GM turbo full tank to sucking air 390 or so miles, after ATT 430-440 miles, that R&D caused me premature death of an IP, running them dry of fuel is not advised, I carried 5 gallons of fuel in a can in the bed so that when I ran out I would not be stranded.
Trip was 450 miles each way doing that every other weekend, same grades, coffee & pee breaks at same spots using cruise control is about as repeatable a condition as one can have.
Many times on phone with Slim Shady, GMCTD and a host of others to help keep me awake knew by my fuel gauge level how much longer of a trip I had or when I'd be stopping to topping it off, 26 gal tank plus another 5 gal would get me either direction and give me 2-3 days local driving in MS or GA, last 2-3 gal is hard to use as it sucks in a lot of air as the tank sloshes away from the pickup tube.
That is about as real of a test as one can do, not a seat of pant guess, actual results, fill up to the filler neck until it started stumbling for want of fuel.
Those that have installed after me have reported gains yours is only one I've seen reporting a loss, 1-3 mpg seems to be the level of gain wholly dependent on health of the vehicle, and driving style, were i able to drive at 1700-1900 rpm I suspect the mpg on mine would be better, but as Sammy Hagar says "I can't drive 55"
