6.5TD Burb
Member
Anyone see the new(?) solid Dorman balancers? Link: http://www.dormanproducts.com/p-5226-594-170.aspx?pymmeid=6922777
Pic:
Pic:
Ones the HB, and ones the crank pulley?
Personally, I believe Fluidampr's engineering is the best. I did call and talk to one of their engineers and was very impressed. When I have some more money, I'd like to put them on both rigs.
-Rob![]()
Fluidampr's are not as great as what they would like you to believe. Pointless to have your rotating assembly balanced if you use one of these. Their properties change between from startup cold to running warm. Any respectable machine shop or engine builder will tell you the same if they know what their doing and have your best interests in mind. As long as you buy a good quality balancer and keep it from getting an oil bath from these motors you'll be fine.
Yes I do realize I'll get some flack for saying this as it appears Fluidampr's are worshipped around here. Never seen so much about these till I started researching diesel performance lol
Go ahead and fire away now... :mad2:
