matuva
Tropical 6.5er
The serpentine pulley is itself balanced. Put it on or not will do nothing in a balancing process
internally balanced engines have a zero balanced flywheel and HB externally balanced engines have a weighted side to them. And yes they are universal for all like engines ie all 6.5 diesels etc. That puts them within spec. When you have an engine balanced they are using a tighter spec than factory.
Then why is it necessary to have on the engine while its getting balanced?
So the HB must not be balanced, it must have counterweights to bring the rotating mass closer to balanced specs.
The crank pulley is balanced, thus doesn't effect engine balance.
I put the Dorman HB and Pulley on the '95 and no problems. AC Delco is probably made in either Mexico or China. Most all low technical value products are made in China anymore. Socialist unions have priced themselves out of jobs and work, so it only makes sense that a socialist country steals their work.
