VW_Lupo_TD
Active Member
Lift Pump 98 K1500 OEM - 25117340
Lift Pump 97 K2500 OEM - 15754298
Lift Pump (Higher PSI) OEM - 25115224
ok guys quick question, this morning i changed fuel filter and of course noticed no fuel coming out of filter manager drain hose when I tried to drain the manager. Exactly the same as the day before I left Detroit, so I knew the deal.
But I am getting tired of the lift pump issue.
Questions:
1. If i get an OE pump - which one (see part numbers above)?
2. Is there an alternative to using this type of lift pump ?
Something more reliable ? (kennedy?) that is a direct plug & play ?
3. If it cannot be plug and play - go ahead give me the hardcore solution that will last forever. (kennedy ? Walbro ? etc.?)
Hell - i do not even care if it runs with the OPS, relay and all that crap. I need a pump that will suck a golf ball through a garden hose and a flip switch ;-)
Someone needs to do a write up for this and give every one the opportunity to get rid of that design once and for all.....
(Yes, yes - I will do a write up if i find something that works)
rgds
Questions:
rgds
