GM Guy
Manual Trans. 2WD Enthusiast
I would only try umo with an old 2-cycle detroit. those things could run on the nastiest stuff.
One real quick question...not trying to hijack the thread....How much 2 stroke oil do you guys recomend per tank or per gallon?? Ive just been using one of the 1gal mixers every time i fill up.
Only way to prove it in or out is trying it.The OS may or may not throw a tantrum.
yapping it wont work is no proof.
Dont let fear or common sense stop yeCummins gys all run 128:1 cause of the VP44 issues. I'd say that's a good ratio. I would not use drained motor oil in anything. I got enough repairs to do without tempting fate to do more.
Dont let fear or common sense stop ye![]()
There is an encoder ring inside with slots that coincide with the firing order through the injectors. From what I understand, the optic sensor shoots a beam of light through this encoder ring. Whenever the beam of light reaches the sensor on the other side of the slots, it triggers the PMD/FSD to fire the solenoid which starts the injection process. The best analogy I can give you is like the Mallory Unilite distributors. The rotor has slots in it that allow light to complete the circuit and fire the coil.
there's aparently plenty of service stations that dump UMO in their bulk fuel tanks,I doubt they filter it either.
I for one am gonna try it in 1 of my tractors ,as soon as i have a working filtration system figured out. pushing the UMO trough a final 2 micron filter should render it clean enough.I plan to mix it 1:3 with diesel.
IMO,Its better to try and fail,than failing to try.
i plan to use mechanical filters,found 2 sofar, still looking for a 2 micron.Filter replacement may be too costly to reap savings... Only one way to find out! Keep us informed!
I go trough roughly $5-6000 worth of diesel a yr at current prices of 60-70 cnt a ltr.A 1:3 ratio could save a lot of money.
Thats where it becomes really not as useful in an elctronic injection 6.5, since I'd imagine more than 1:16 ratio would not work reliably. Unless youve already got the filtration and storage for other vehicles, then it might be worth it, or you put a whole lot of miles on your truck in a year.
