mr_goodwrench_06
- Messages
- 106
- Reaction score
- 1
My temp gauge isn't working. It worked before I installed the 3" body lift. My voltage gauge reads way too low, but it always did.(10v v.s. 14.2 measured at battery) My fuel gauge sometimes jumps around. My glowplug light does not come on, but never did. I think I have a ground issue but don't know where the factory grounds are under the dash. There is a stud on the firewall on the passenger's side with nothing on it, is that a ground point? I ran some new grounds too...firewall to passengers side battery, fender to passenger side battery, rad shroud to driver side battery...all connections are new and clean and tight. Side post stud mod done. I was thinking of adding a ground from the frame to the battery. Both batterys are grounded to the engine. I also added a 10ga wire from alt. to driver side battery and from the alt. to the power distribution stud. Also an 8ga from the power distribution stud to the driver side battery.
Thanks for any help,
Bill
Bill
