buddy
Active Member
And who has 180* T-Stats?
Mine is, but I have yet to install any cooling mod.
This is what Bill sent me and it doesn't engage at all.....
FYI I just ran the burb over to Ga from Ms last nite, since 2007 it has Heath pump, spin on clutch, and 9 blade plastic fan, 86F outside temp, running 100% load, 100% APP, 107 mph max speed, max temp on H2O was 207F, normal average was 199F at 60-85 mph. When I bought the burb it would go to 215 F just idling in traffic, I would keep it cool by turning on defrost to pull off some of the excess heat, DEEP rad and AC core cleaning and Heath cooling system upgrades were the ticket to fixing my overtemp situation. In 2006 I put on TM set at min setting scrapped vac pump, 4" exhaust, and GLE program, and remoted the FSD. Also has Lube Specialist lines and cooler, and FS2500 bypass kit installed in spring 2008
I'll be posting all collected data later in the week (burb soon to also have ATT took baseline data) sans EGT/mech boost/or BP (no EGT on the burb yet). Highly recommend you call Heath vs. posting here, they don't monitor the site much for issues, so won't be aware of any issues you still have after installing their kit.
Hey TD. Did you go with the dual thermostat setup or the single. I thought I remembered you saying you were going to try the single, but am not sure which way you decided to go.
I gotta say, I like the Heath boys but what GJF is sayin I might be agreein with. I have not had a chance but I was going to pull the stock steel fan off my 2000 and put it on my 95. I cannot use my stock 95 one anymore cause the Heath water pump used center hub. I have long suspected that fan is not drawing air and now that you posted this Iam going to swtich the fans . I have never "heard" the Heath fan pulling air like my factory one does. what's even more whack is from your sig you are running a ATA so you definitely should not be having problems.
Burb still has dual stat, single stat going on the new truck project engine if I ever get down time to install it, too many projects going at once and commutes Ms to Ga are a time killer.
Finished the o/h on my 90 GMC C1500 4.3L for my son, next project is powerplant swap from this burb into a 96 body, then after that the project engine into the truck.
I didn't even have to do that. It fit fine.Corrective procedure when installing DMax fan is merely trim the 90* angle lip off your fan shroud.................
I know but compressor had died so couldn't run the die grinder and needed to get the truck on the road ASAP.
