M123KT-450
- Messages
- 442
- Reaction score
- 0
(1)
I have heard lots of conflicting stories about how to tow a trailer or haul loads with the 4L80E.
Some say just leave it in OD.
Some say run it in DD.
Some say Run OD till you hit a hill then down shift to DD then shift back up to OD.
Now i'm sure i'll hear a bunch more of these 3 claims again but i would like to know whats the Correct GM operating procedure for the opertation of the 4L80E ?
(2)
Now for Fluid type is this better off on Dino oil or run with a high end synthetic Fluid ?
How often should the fluid and filter be changed in these units ?
What type of fluid exchange would be best for these units ?
(3)
Now how about the cooling of these units ?
Do these Trans pan coolers work ?
The extra 1qt in volume with flow threw cooling tubes ?
or
The extra 3qts in volume with cooling fins ?
(4)
Now is the GM factory Cooler mounted by the Radiator the best way to go ?
or
Should and after market unit unit be used ?
some say get the GM cooler and bypass the Rad.
Some say get the GM cooler and run it inline with the Rad.
Some say after market next size bigger than your gross GVWR inline with Rad.
Some say next size bigger than you GVWR bypass the Rad.
Whats the best setup For the 4L80E ?
Sorry for the long post guys just trying to find out every thing i need to know about this transmission and what works best. i have numbered the Questions so you can either answer all 4 or any combo of the 4 . just note the number or quote the number so i know what question or questions are being answered.
Mike
(2)
(3)
or
(4)
or
Mike
