ak diesel driver
6.5 driver
mine just used an oring I'd think it would be easy to find
Yeah, scribe where it was. Very sensitive. If you don't put it back exactly right your gonna have problems.Is there anything I should know before taking the OS out? Like is there a way to screw it up if not done right.
I'd hook a temp one on and see what you have when you are cold cranking
What was the result of running your lift pump prior to trying to start?
So you've got decent fuel delivery, at least to the IP. Sounds like you're leaning toward OS being bad, I don't have any experience with that. I'd also wonder what Bison was suggesting, what your cold compression is.
