wiring diagram for fuel gauge ground
philmathews68
rockford 'il
ok i have changed the sending unit by pass the switch box for the tanks and still have a wild gas gauge it will start on full the drop to empty then bounce around then goes back to empty can any one help please
What are you working on? Fill out your signature, and let us know what your working on so we can help answer your question. Also fill in when the problem started, and what has been done so far to correct it.
gas gauge
its a 1998 chevy c3500hd with dual tanks have cleaned the grounds change the cluster and the sending unit with all new 3 different times and still get the same thing when you turn the key on the gauge will go to full then it will start bouncing then goes to empty and stay there
You say you have dual tanks, have you done both sending units? And I believe the 3500HD's used a dual tank module to control the fuel gauge. I've never messed with one so I can't tell you where it's at, but that is where I would start ooking at first.
ok how do i by pass balance module so it will read for an aftermarket fuel gauge and fuel pump i have completely removed the rear tank to put a wheel lift in but i can not get the fuel gauge to work so i went out and bought an after market fuel gauge and fuel pump now i have 4 wires two blacks,purple,gray i know the larger of the blacks wires goes to fuel pump along with the gray then the purple is to the fuel gauge so where does the last black wire go to
