What's your feeling on twist nuts ? I like those as well. I usually seal them with grease.
I solder any splices audio related, and anything timing signals related (PMD, fuel solenoids, distributors). Thats just my preference.
Typically I strip little over an inch on each side, around 18AWG, overlap so wire insulation is about 1/2 inch apart and twist it around each other so the splice is in line (not like a wire nut would do it perpendicular) and it forms a good tight joint that when you pull it would tighten the joint for the most part. Definately dont want to heat the wires too long as it will definately become brittle. Have to have high powered solder guns for 2 thick 18AWG and lower splices, not the little radio shack $15 deal.
Looking back at this thread I cannot say how much this is true, the thin "crimpers" are useless, never use them, get one that actually folds the crimp over itself, like a U shaped crimp, not just smashing it.
This was my response the above question just about tapping into an existing wire
I just use a knife and cut away a little spot of insulation and wrap and twist a wire around it, I solder if its permanent, and wrap it with electrical tape. Or you can get a butt connector, cut the wire, strip the ends, crimp one end down with one of the cut wire and the other end with the other and an extra wire, but then the butt connector has to fit two wires, if the other end wont be tight with only one wire, just strip it back far enough to fold it over.
