Morning all.
I recently bought an imported Winnebago RV in the UK. It's a 97 model on a 1996 P30 chassis. There are so few here and knowledge is very limited, my plan is to get it back working and on the road, before moving in with the family and travelling full time around Europe.
I've got a problem with the vehicle, which I think is transmission related. I'll explain what I've done so far.
I've got an OBD2 port, with only 5 pins (1 at pin 16 so I have a powered port.) I can read fault codes with an OB2 reader, but I believe it may be an OBD1 system, as info is limited. I only had 1 inactive fault P1218, which is something to do with the fuel injection system. I cleared it, MIL light cleared and fault did not return. I don't think it was related to the issues I'm having.
The vehicle has sat unused for 7 years and has 41,000 miles on the clock. Before doing anything I changed the engine oil/filter and fuel filter.
The dipstick for the transmission was broken, and I made a new handle to remove and check it easily. I dropped the pan and reset the level of the dipstick to be where the pan meets the transmission housing, as advised elsewhere. I then topped up the transmission with new fluid. It took about 1.5l more than removed. The old oil was dark in color, but did not smell burnt.
When selecting gear, it is sluggish to pull away, but picks up speed quite nicely once moving past 5mph. It does not change up or down gear at all. Reverse works. This leads me to believe the vehicle is in 2nd gear and issue is to do with the electrical system, causing this limp mode as such.
I checked the transmission fuse (10a) and there is 12v at the gearbox connector.
At the connector, I checked the resistance of:
1) Solenoid A - was good.
2) Solenoid B - was good.
3) TCC - was good.
4) Force motor - was good.
5) Transmission fluid temperature switch (TFT) - nothing. (I was expecting between 4 - 6 ohms).
I suppose with no fault codes, this is an electrical issue, causing the transmission not to shift and remain in it's limp mode state. My speedometer works as it should, so does that rule out the input and output speed sensors? Would the TFT, cause the limp mode, or is it even at fault?
I appreciate any guidance on this, as I need to get the vehicle roadworthy as soon as I can. Thanks.
3) TCC - was good.
