Matt Bachand
Depends on the 6.5
would putting 2 or 1 stud on before head may help in alignment of heavy head?
That was what I originally thought. You put the heads on first and then screw in the studs. They have an allen key on them to screw them in. I love them.
you should always do a multipass torque down just no need for the 90* turns
felpro gaskets are called perma torque because there is no need to re-torque, they are permanently torqued the first time you do it.
although I just did my head gaskets and used TTY bolts and cometic gaskets that were supposed not to have been re-torqued the driver side blew after only 30 miles and the torque was way low.
When I took them back off they were so loose it was scary.
You guys do know that if you're not using an angle gauge on a TTY bolt, you're not doing it right.
Right?
For example:
http://www.cdxetextbook.com/toolsEquip/hpt/measuring/usetorqgauge.html
TTY is designed for one thing only and that is to eliminate the re-torque step completely.
You can reuse a TTY bolt if it has not gone into the 'yeld' of the bolt metal. Some engines are less prone to do this...
Studs are tightened in 3 steps.
Yes, you can set the heads on the dowels and then put the studs in.
You should put the gasket down before putting the studs in as the gasket does not go over studs easy. But I have done it twice missing that step with no problems.
You would have to skip the locktight step putting the head on in frame as there is no way to torque the studs down very well with the head on unless you are fast and can drop them all in and torque all the nuts quickly...
You mileage may vary but it seams when I pull a head the rest of the 6.2/6.5 needs to come out and go to the scrap yard.
