NVW
Heat the washers to a dull red and drop them into a bucket of water.
wouldn't that harden the washers?
Copper doesn't temper by the same process as steel.
Heating and quenching copper causes it to anneal.
Cold working causes it to harden.
Cheap Item.....I'd buy a set of "crush ring/washers" just for the piece of mind.
I think i got a return line kit with the washers for $20 or a bit more off ebay.
The push rod is missing? A collapsed lifter could cause it to fall out of position. I can't help you on where it went.
