94dually
Hello all,
ok so im new to diesels and am lost :dr: (work on gassers for a living am clueless on diesels) and have found tons of different reasons that might be causing this issue. I dont know anything about truck. it appears to be completely stock. Hard to start when below 50 F unless plugged in and has alittle white smoke but mainly clears up after a min or two...thinking glow plugs but need to test them. My question though is after about ten miles or so it started smoking again and smokes from idle up to about 35 mph or so and clears out unless i hit the throttle. power issue on small hills and check engine light is intermitent during this time, but vacuum pump is not showing much so not sure if it is part of the whole picture or just the power issue?. it isnt a complete whiteout however it is enough that everybody around notices it. its not coolant and blowby doesnt seem to be the issue. help? thanks ahead of time on any help and if more info is needed just let me know....im starting to think my friend ripped me off :rippedhand:
