Acesneights1
www.fordcummins.com
All I gotta say...
I would do this in a heartbeat. JK Auto from DP did one and he used an intercooler. You can't beat a Cummins diesel. It is IMHO by far the best diesel out there. Too bad they couldn't get it right with the 8.3. What a POS that engine is. Amazing how similar they are though.
Orrum, the powertroke webfoot thing you spoke of was the F250s pre Superduty. Fords IFS sucked ass and could not hold an alignment. GM's holds alignment better but it's junk. Atleast with a ford a straight axle swap is a heck of alot easier..if yo can find one. I was looking into a straight axle swap for my Burb. I scoffed at the idea until I saw it first hand in Joey D's truck and at Valley Off road(he does them and the GM striaght axle can be used, just more work.) If I was considering a Cummins swap, I would go straight axle as well. I will say my Powerstroke out towed my cummins 24v. Cummins is a hell of alot stronger and easier to work on though. As far as using the 4l80e, Dodge trannys are junk. Get an adaptor kit and use a Comushift. You could do all this for less than the price of a new Motor from GM and it would be 10x stronger, just alot of work. Guys replace the 6.xx with 6.xx because it's a drop in easy swap but a Cummins conversion...Now your talkin serious truck.
If money were no object, find a 54 block or later(56 the best) 24v and P Pump it...Now that is serious....
the questions is what's better Cummin or strokin ?? :rof:
All I gotta say...
