robzombie4551
robzombie4551
Thanks for sharing that info. That is close to the turbo I was gonna use, I was contemplating the hx40ll with the t4 and 16 cm E/H preset at 20#s
Pics of the install ??Ive been running the hx-40 nock off with the t3 flange on my 93 for 10 months now with no problems. it was well worth the money to me.after i finally build my engine i will continue to use it. it spools just as fast as my old gm-3 and keeps pullin. the waste gate comes pre set at 18 psi. my engine with 220,000 miles on it has no prablem building boost with the turbo.
Damn, I was just informed that it was an incomplete project and needs further refinement.:mad2::mad2:
However I'm confident that our guru might be able to figure something out someday.:agreed:
i will get some pics up shortley. camera was inop when i did the install.it was the emusa turbo.cant remember the exact price. it starts to spool just a hair faster the the gm-3. my egts are alot cooler even when i get on it the temperature even builds slower. iam going to install a charge air cooler soon.
and there we have the proof that these turbos work... which one did you buy? EUMSAII?(i think that is how it is spelled) does it have a serial number? how much did you pay? i have seen these turbos go down to around $225 + shipping.... how does it spool up? do you have lower EGT's than the gm-x turbos? i would just like to say thanks for sharing.... for around $400 , it makes these turbos a very attractive choice...
know as far as higher rpms my truck pulls alot stronger in the high rpm range than the gm-3.
I'm a bit confused though...The HX40 AFAIK was for the 8.3(pretty sure my 8.3 had one) so why is the chinese knockoff a T3 when the real one is a T4 ? Was this basically made thise way to use on other apps ??
