Which antifreeze
@Stoney be sure to flush all the dexcrap out good! I know on some blocks there are drain plugs that can be pulled to drain the block, I went to pull mine when I installed the new water pump and discovered my block doesn't have them!
I have always run Amsoil Low Tox with distilled water and water wetter. 60/40. After a good flush.
I never had problems.
Good? Bad? Just lucky?
I actually run the max mix of 70/30 for the higher boiling point and lowest freeze point with two bottles of water wetter for the Burb and 70/30 w/1 bottle water wetter for the Toyotas.
