Rockabillyrat
SlIgHtLy StUpId.
Its not going to flow alot out of the return fitting. If it does that would indicate and issue with the pump. Return volume is a combination of fuel making it past moving parts like the H&R and advance pistion, and the the vent wire in the head. If the H&R or advance piston is worn then return volume will increase.
Like I said return spec is measure at 2000rpms for 1min at WOT, with calibration fluid at 110-115*f. With what your doing a very small amount of return is normal.
If your not getting fuel to the injectors it can be a number of things besides sticking parts... did you confirm that the metering valve is moving? Is it making transfer pump pressure when your spinning it with the drill? Those are two easy things to check. Everything else requires some disassembly to check
