RadioMan
Recruit
So dont listen to an argument that it doesnt spend enough time in the radiator.
Made my living as an Electrical Engineer, so I will readily admit that my understanding of thermodynamics, while being better than rudimentary, is still a just a bit beyond the basics. It was one of the very few courses that I actually hated...
That being said: Even as an old retired guy I guess I'm still a student and would really appreciate it if you would share your knowledge with the rest of us. I truely realize what a complicated system this is and would like to get my truck operating as well as I can so that it will run forever :rolleyes5:
-- Well, For as long as possible :smile5:. Since HEAT KILLS - Controlling the engine's heat is, no doubt, one of THE keys to it's longevity.
I guess where I'm getting lost is because my bucket truck is pretty heavy all of the time, even if I'm not towing something. It was showing a tendency to get pretty hot on long grades a while back, but just cleaning the radiator solved that problem. I'd guess that after 13+ years that the water pump impeller is probably getting near the end of its service life and that it should be changed - But to what?
The stock system *seemed* adequate for quite a while, but if I'm going to go to the trouble of replacing the water pump I'd like to do it right and not just make wild guesses based on my inferior understanding of the dynamics of the cooling system.
Now I realize that this will be fairly difficult without going into the math, but to be honest the complexity of those equations just makes my head hurt, so in layman's terms if you would. I mean just basically explain how much heat can be transferred given the tubing size and efficiency of the radiator etc. etc. in these trucks and how much flow that system needs to optimize the heat transfer at the engine's max designed operating temperature.
Please sir, just the end results and not all of that confusing math that you've had to slog through to come to your conclusion.
Thanks in advance Buddy!
Looking forward to being enlightened!! As Lew Wallace said: "Knowledge is power." Or as Don Aarant said: "Nitrous oxide is power"
