Brooklyn Tow
9 11 Never Forget
Whats the 3 bar sensor and which model uses it and how do you tell them apart??
Because 7psi might be 2.5V reported back to the PCM on a 2bar sensor, but 11psi may be 2.5V on the 3 bar. The PCM would recognize 11psi as 7 psi in that scenario. same as installing a boost fooler pretty much.
Louis, just bite the bullet and get a tow tune for the tow truck
No need for a boost fooler then.
I just installed a boost guage and here are some numbers. Hard acceleration from a standstill it will spike to 6 then quickly settle at about 4. Hard accel from about 45 mph it goes about 4 to 4.5. cruizing most speeds on level ground 1 to 2. Uphills 3 to 4. This is a stock vacuum setup. I have 25 inches of vacuum from the pump and 15 from the boost relay to the accuator. Thanks for any replys. g
No if you are able to make good boost with direct boost applied to the WG actuator then you have a leak in the vac plumbing (hard to see sometimes in the nylon "hard-line") other vac system leak (check all connectors /lines) or bad WG solenoid.This might be a dumb question. Could it be the wastegate accuator? I am getting 15 inches from the solenoid to the accuator but before I could not manully move the accuator bar at idle and now I can. Its stiff but movable. Sorry if these questions are tiresome. Thanks g
X2 and with adjustable fooler you can better tune for performance with a stock setup, even the 3 bar MAP can code with the right conditions you may code, I ran with fooler for years until my vac system started acting up, then I went TM & fooled, & eventually going reflash.I think its been mentioned in the past, but a boost fooler is adjustable and cheap.
