JohnShead
DTC 34: Injector Pump Stepper Motor
DTC 35: Injector Pulse Width Short
DTC 36: Injector Pulse Width Long
DTC 39: TCC Stuck Off
My truck was running great, no codes at all but I couldn't keep my wrenches off the old beast. I had a (25 year old) hydraulic hose burst and decided I would change all of the hoses along with the pump and oil cooler. To resolve some electrical issues years ago I had installed an 8AWG THHN wire (not automotive but that's what I had in a box), I bolted it to the firewall, then to the grounding stud on cylinder no 8's intake, then to the stud where the right side battery is grounded, then to the stud where the left side battery is grounded, then to the frame by the PS pump. I recently resolved those electrical gremlins so I decided to remove that ground wire. The problem was all in the plugs that attach to the side of the main ignition switch plug, they had some connectors that were intermittent and some were just poor connections. I also had been procrastinating on a repair that I decided to do this time since the truck would be inop for a while, I had a minuscule coolant leak coming from under the timing gear cover. It was such a small leak that I tolerated it for years, sometimes it wouldn't leak at all and other times it would leave a silver dollar size puddle on the garage floor overnight. I finally decided to fix this and for the umpteen thousandth time I tore down the front and top of the motor to get at that leak. I chiseled a nice new mark on the IP so it would be back in the same position when I put it back together. I took the nuts and the gear off of the IP to pull the cover, cleaned it all up, applied new RTV, and reassembled it all without cranking the motor at all. When I got it back together she fires right up and seems to run fine but I get the above codes. With those, of course, I have no TCC lockup or cruise control and I'm pretty sure it's not going into 4th gear. Does anyone know if I might have knocked something loose to cause these codes, or do I need those grounds maybe?
