88gmctruck
02GMCtruck
Heh, I'm working on it. This weekend I'm thinking a lineup picture is in order.
Comparing it to a duramax is just....... meh. There isn't a point. The duramax is far more powerful and much quicker. I do think that the seats in both my 88 and 99 (the 88 has seats from a 98) are more comfortable than my 02 or devin's 07.
Can we go for a drive tonight? i.e. Can I drive it tonight? :hello:
I'm about 95% certain I would rather have that truck than my 07.
You should have Devin bring his 83 out for you to look at![]()
It is true, the GMT400 platform was where comfort came to be, yet they weren't loaded to the hills with unnecessary BS and tons of plastic.the 90's era GM trucks are a perfect mix of truck and ride. The older ones are a bit too much truck, the newer ones are a bit too little.
Well, my 88 is just darn simple, but honestly I prefer the dash layout of my 02 over the 99. The 99 seems like it was kind of a transition, and in the 02 everything is IMO, where it should be. I do think the seats in my 99 (and the 98 seats in my 88) are so much more comfortable.Right with ya on the new trucks. I really don't like my '09. Trying to get the seatbelt on with my duty belt on is a royal PITA, never had that problem before. Cab setup just isn't comfortable. Don't know if it's just the way I sit or what but placement of everything is just off a little. Cupholder, radio controls, window and lock buttons on door, steering wheel angle. Not quite in the right place.
Yup, it even has the original manual, warranty book, diesel supplement and case. I also have a small receipt stack from maintenance and such done to the truck, and it has had normal services done, and all the small things that broke fixed, so it really was cared for. The owner was down on times and really, really did not want to have to sell the truck, she was very sad to see it go. I did assure her it was going to a good home.Nice buy! The truck looks really clean.. And even factory gm floormats I see! Little things like that usually show an overall care by the original buyer in my opinion. I'm sure you will love the 6.5 and nv4500 combo. That's what's in my 96 and I can safetly say that it's the one truck I will never sell under any circumstance. Good luck with it!
That looks nice. Does this one have a 9 blade steel fan and spin on fan clutch? A late 99 or a 2000 with the good cooling setup already would be nice. You may want to just put the restrictor on the water pump return fitting that allows coolant to bypass the radiator, because of the dual T-stat bypass setup.
A decent exhaust setup, and a PCM reflash and this thing will be treating you right. Amsoil nano-filter when you need one. And maybe the 3" PVC elbow intake mod, since its really cheap.
What's an Amsoil nano-filter? What makes them better than an AC Delco?
