dangerousdave
1994 6.5 Suburban
Lots of great info here, specifics help simplify things;
Year, model, modifications>
Thanks to all.
Thanks to all.
Funny thing happened last Thursday . . . At highway speed, the tranny started to flutter the TCC (unlock - lock) and 4 - 3 - 4 shifts. Looked over at the Edge and noticed that the ECM's coolant temperature was all over the place (dash gague was rock-steady). When it dropped into the 150's, the motor sounded like a machine gun. When it dropped under 130 F, the tranny started to unlock the TCC and shift down to 3'rd.
Changed the ECT sending unit in the thermostat housing last weekend and now the ECM's temperature is rock-steady and no more machine gun or fluttering tranny.
Over the years I have dropped big bucks into the 4L80e what I found is that it is fully functional at 28 deg f. however pure synthetic should be used to protect it at extreme low temps dino fluids don't offer the low temp protection. Using conventional trans fluids in extreme old you must warm up the vehicle longer for longevity of transmission.
Look at the temp tables you find 157 deg f. is max recommended operating temp for the 4L80e I'm below that on the hottest of days I run 3 coolers the radiator, the large fin plate B&M super cooler w/fan and a large low pressure drop fin plate cooler.
There are those who claim running the trans so cool allows condensation to add lots of water to the mix this is not true because the converter always gets hot enough to boil off any water resulting from condensation so it vents.
CTS's routinely cause these kinds of issues.
I would like to see a copy of literature that says 157 . . .
Do you have a copy of it? So far you are the ONLY person I have EVER heard say this 157 degree max temp, and even on google and bing searches you are still the ONLY one who has said it. I HAVE found SEVERAL GM documents stating 180-200 as being the NORMAL DESIGNED trans temp to run, and 235 as being the max reccoemnded temp with DEX III or 270 with DEX VI. So I would like to see a copy of this document. Even my ATSG doesn't have anything in it about this 157 degree max temp. Even all the trans bulletins from aftermarket shops stil lall reccomend running 180-200 as converter outflow temps will be high enough at that temp to remove any moisture in the fluid. So until I see otherwise, I will stick with 180-200. Even brand new trucks with the 4L80E i nthem will run 175 running down the road empty.Actually it's at idle and warm 120 deg.f to 158 deg f. page 95, ASE 8 ENGINE PERFORMANCE 6.5TD, MODULE 16 as read via TECH 2.
I stay below 158 deg f. at speed.............
So, a stock transmission cooler is in the radiator where the coolant is anywhere from 180-220 depending on engine. This is to cool the trans fluid? If 157 is max how could it cool it with a hotter fluid? My 01 suburban has a stock trans temp gauge, and at idle with engine at 215-220 the trans is 160ish. Driving the hi way for 1/2 hour it is 190.
I'm thinking your dealing with a typo and it should say 257 maybe. That's around red zone on the gauge (maybe 270?)
Actually many trans coolers were installed BEFORE the trans fluid reached the radiator. Do some flow checks and you will find this out. GM KNEW a liquid to air cooler is more efficient cooling higher temp fluid, plus in doing this they could maintain a more ideal 180-200 degrees trans fluid temp. They have flip flopped through the years on this, but many still got put before the radiator. And my email is [email protected]. I'd like to see this and compare it against factory info.Perhaps a typo however it maybe closer to real operating temps for the trans to last much longer.
As you know the trans cooler is installed on cool side of radiator to initially cool down much hotter than coolant trans fluid coming from converter.
My first rebuild was after the warranty expired and that's with the aux cooler too I've since gone to over build and not looked back.
The Amsoil synthetic fluid is as clean as the day it was installed back 2009.
You misunderstood what that table is for. That is not an ideal temp range, that table describes a typical valu one would see if they started the engine and let it idle until the lower radiator hose was hot(as in stats opened and flow made it all the way through the radiator) with it idling and no load applied. It is in no way a table saying the min or max desired temp, its just a typical valu chart used in a training course to tell technicians what standard values they should see under controlled conditions. I've been through actual training courses, so I've seen these kinds of manuals before. If you go back and look you can see it even says student workbook on the sides of the page. You may want to correct where you have quoted this info as you have misunderstood this materials intentions.
FERM has corrected me on misunderstanding what was presented in in the above statement, sorry for the error.
Meh, no biggie. Live, learn, and grow thick skins.Personally, I lost count on how many times I got corrected
So . . . Back to the ECT / Tranny behavior.
Looks like the combination for TCC lock is ECT at / above 132F and TFT at / above 70F. Already knew about the TFT figure from prior observation. From last week's episode with the failing sending unit, was only able to loosely affiliate the TCC lock with 130F as the temp swings were too wide and too fast. Last night ran some errands and had a situation where the ECT started at 120F and TFT was 100F. TCC would not lock until the ECT got to 132F.
