dually man
OK, it cold here now and my 1984 gmc with 6.2 starts after 17 seconds of manual glow plug time. starts fine but misses. the truck has true dual exhaust and out the pass side it puffs LOTS of blue smoke, but not out drivers side. The engine also sounds like it is backfiring into the intake with loud random pops for about 45 seconds. At 1 minute and 30 seconds the exhaust on both banks is clear, the engine runs perfect, smooth, lots of power.
History:
10000 miles on gm goodwrench rebuild, uses no coolant. No oil usage after 3000 miles, no leaks. always used power service lube with fuel. NEW fuel filters, electric lift pump, timing set on the mark, no timing chain slop, very little black smoke under HEAVY load 7000 lbs trailer. injection pump is set to stock fuel rate. truck is a 3/4 ton 4x4 wih turbo 400 auto and 4.11 gears, it gets 19.5 mpg, like I say it runs AWSOME, it just smokes out theat one side like crazy oncold start. Cold start after like 6 hours of sitting makes very little smoke, but I do have to use my glow plugs for about 10 seconds. outside temp is 25-35 degress F. Thanks for any help
History:
