Michaeljp86
EVIL GENIUS
Lots of videos on youtube with runaway diesels. Lots of turbos destroyed with rags and gloves.
The plastic caps of aerosol cans fit real good on a lot of tractor intakes.I had the upper intake off for a reason lol.
Nope. I had 2 bad gray Standynes. I will never use them again unless they are updated/changedI would say so, started reading then seen the date of the second post. LOL
well, I liked the last post. LOL
Did You install a grey Stanadyne PMD ?
And so, the flight systems module is the one to get ? ? ? ?Difference between standard and Mil-Spec electrical components internally. And the FS unit is still cheaper than the Stanadyne using better components than Stanadyne.
Yes. Flight Systems/Diapco (same unit, just rebranded) is the one to get. The gray Stanadyne still isn't up to snuff compared to the FS unit, although it is (debateable) better than the series of OEM black Stanadyne PMD's it replaces.And so, the flight systems module is the one to get ? ? ? ?
It's up for grabs. From recent history Flight Systems seems to be the hands down winner.
I was pretty soured on Flight Systems for quite a while. I had a few of FS PMD's when they were crap.
I've actually had my best longevity out of the old black Standynes.
Mostly because the new Flight Systems haven't been on any of my vehicles for as long as some of the black Standynes lasted
Since the PMD's no longer have to attach to the pump, I have always failed to understand why they keep making them so they can. I would think they could make a better unit if they lost that requirement
The heck of it is, I do not know which 94 K3500 I made this thread about.
The Dorman unit is one of the rebranded with their name Flight Services-made PMD units.If the Stanadyne currently on My truck ever fails, I`ll be trying an FS unit next.
I do have a Dorman unit for a backup. After the warranty on the Stanadyne is expired, I`ll install the Dorman then use the ST unit for a backup.
I believe that to be incorrect. As far as I knew Flight Systems are made in the USA and Dormans are definitely made in China. I have heard bad reports on Dorman performance and longevity - spottyThe Dorman unit is one of the rebranded with their name Flight Services-made PMD units.
Bad luck on your part buying a Flight Service at that time. They had a manufacturing lot with a defect that caused a failure. FS quickly corrected the defect and honored their warranty. Their units have been pretty much bulletproof since.It's up for grabs. From recent history Flight Systems seems to be the hands down winner.
Since the PMD's no longer have to attach to the pump, I have always failed to understand why they keep making them so they can. I would think they could make a better unit if they lost that requirement.
Then Dorman must be using a CKO of the FS unit, because the cases are essentially identical except for the printing. If that's the case then it is news to me because originally the early Dormans were rebranded FS and sold about $30 more through auto parts stores than buying the FS directly or through authorized dealers.I believe that to be incorrect. As far as I knew Flight Systems are made in the USA and Dormans are definitely made in China. I have heard bad reports on Dorman performance and longevity - spotty
