buddy
Active Member
A lot of nozzles are rated at 100psi, so beware if pumping 200psi through them youre getting twice as much volume than you may have intended. And check the burt pressure of the lines used in case injector doesnt pop open or some other clog stops it up. Too much pressure might also screw with its spray pattern.
