Walbro FRC-10
@ghostrider500 how is the FRB-11 doing for you 2 months later
The truck has been running like a champ. Mind you, it's far from a daily driver, having only last month passing 100k miles, but I did use it to tow a 7k load about 200 miles and had zero problems. Still haven't hooked up a pressure gauge so can't give any concrete numbers, I did try to bleed the fuel lines after the towing, through the top of ffm filter, and I had barely enough time to turn the key, see fuel flying out the hose into my 3lb coffee can, and get the bleeder screw turned back off before it overflowed the can. Flowing way more fuel than the frb. So I'm totally satisfied.
