Waiting on a tow trying to figure codes
Did you check your glow plugs?
Did you load test your batteries? I've had several new but bad batteries in the last several years.
Did you do a complete lift pump test? Including running about 3/4 gallon into a jug? I use a gallon pickle jar. Let the fuel set about 20 minutes or so and look for crud and water bubbles on the bottom.
Check the oil and coolant.
Check/clean the grounds add as necessary. I add a ground to the battery box to replace or augment that little screw to the fender. From there, on the same wire, I run down to the frame ground by the starter. I run a ground from the battery to the stud at the back of the intake. I've seen several instances of that stud losing ground.
I ad a ground from the heater blower to the dash support bolt right next to it. That gives a backwards route for the PCM to get ground. It also gives relief to the undersized stock ground cable for the blower.
Did you try a known to be good PMD?
Most times the problems are simple. It's just a matter of tracking them down. Usually the problems are found or corrected by the time you get through all of the basics.
