GM Guy
Manual Trans. 2WD Enthusiast
I have a few rigs with bad vacuum lines (all VIN F) so it is just the lines operating the wastegate. I do know diaphragm can fail, but these lines have obvious rub through areas. so I was wondering, what has everyone still running the vac system doing for lines?
can you use regular rubber vac line, or if the little rubber reducers are still good, can one use tiny plastic air lines that are used for roadranger transmission splitters? surely if they can run a lot of air psi, surely the hard plastic could pull some vacuum, but I may be mistaken.
or is the OEM lines affordably priced? I cant find any on Rock Auto, and have not checked the dealer.
Before it is brought up, I would like to go ATT on a mechanical engine, but on the electronic ones I will stick with GM turbos for now for pure cost savings, they definitely are not perfection, but they are the cheaper solution if aquired good used, but might end up with ATT in the future. Also, I have heard about poor empty fuel economy with a turbo master, so I do plan on staying vac system.
