Pepperidge
Member Advocate
a DMAX conversion may be in your future
seems the way to go...
506 blocks from 97-early 99 were famous for cracking in the #8 cylinder about mid way down. This crack doesn't let alot of pressure in as it is midway down the cylinder wall, but will spray coolant into the engine when the piston goes past the crack. This was all to common back in the late 90's, and was why I mentioned it early on.
do the tstat trick first then you can zero in on where to look when pulling heads
