BrokenTech
I just Bought a 98 k2500 6.5 liter Diesel that has148000mi. I drove about a 130miles and had to had a gallon of coolant and the oil level is about a inch above the full mark. There is no visible coolant leaks. The oil is not foamy/milky but the oil is thick and smells and feels like coolant is in it. I did a psi test real quick to 13psi (pump Handle was broke) and started dropping real quick, the engine was hot. I did see a white puff when i started it after the psi test. The surge take does not appear to be getting blow by in it. The oil fill cap had droplets and was a little gray in color. I am letting the oil sit for a few day and am going to drain the oil to see if any coolant it there. I will post pics if any thing looks out of the ordinary. Any helpful advice would be appreciated before i start removing parts.
