Thanks ! New to diesels.jist looking to do the things I need to for better mpg.having block and heads done next week.so just looking to improve what I can.will be daily driver..I'm looking for dependable and best mpg I can get.tjanks again
Trade it on a modern 2011+ 1/2 ton Gasoline pickup. They get 4 MPG better than these IDI Diesels on cheaper fuel. Less oil and longer oil change distance as well. 14 MPG on a 6.5TD and 18 MPG on said modern 1/2 ton gas engine. As no one wants an older gas engine 1/2 ton there should be some deals out there.
Dependable is a vague term for a 29 year old vehicle.
You have the engine out why?
MPG can be helped if you do a lot of under 45MPH driving and it's an automatic: put a better triple disc torque converter in and then lock it up at 35 MPH. Alignment and non worn out front end parts also help MPG. Return on your investment for a $1100torque converter, $550 rear end re-gear, $2000 front end rebuild ... yeah maybe not worth chasing too hard.
Speed is a major MPG factor. Time is money.
The 1993 has just a spring can for the turbo wastegate. So even with zero throttle it's generating boost in upper RPM's wasting fuel. So the question becomes what RPM and MPH are you running?
