Updated tsb proportioning valve
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
ZEPHYRHILLS FL
If anybody is needing or thinking about getting one of the updated combination/proportioning valves, then now is the time to get one. I've spent the last 4 weeks looking for one and finally found a couple. GM has discontinued these(or at least the 95+ version), and there's only a handful left in the states. I'm getting one for my 99 because it's rear brakes don't do anything, so it NEEDS one. I ended up going to my local dealer, got them to do a search, printout a list of who says they have them left, and started making phone calls until I found one. It won't be long and they'll be all gone.
Part number for the 95-00 is 12548265.
What was the cost (so I can prepare for sticker shock, if need be) of the valve?
Cost me $203 delivered from Arnold Oil Co. out of Texas. This was the superceded part number for the last combination valve available. It was listed as the oem part for half ton gmt-400' for 99-00. Starting in 2001 GM stopped using this unit and switched everything over to the style that used a separate proportioning valve. I know it made a HUGE difference in my 95 when I put it in. I know I called/ordered from almost a dozen different places before I finally found one. The place I ordered from listed 3, but only had 2 in stock.
That's not nearly as bad as I had imagined it could be, but not as cheap as I hoped it to be. I wonder if my '98 K2500 Burb has the new style proportioning valve in it or the old one. How do I go about telling @THEFERMANATOR ?
OK, my 1999 Suburban K2500 8.6+ GVWR has no proportioning valve that I can see anywhere inside the engine bay. One line from master go's directly to ABS manifold and the other goes down to the chassis rail.
What now?
The valve is in the end of the abs unit where the lines from the master screw in. None of the 2500's got the revised valve. The 1500 6 lugs were supposed to have gotten it, but several had swapped this valve in and seen braking improvements.
I suspect when going to a disk brake rear I need locate anther ABS unit for the disk conversion, or?
I had asked earlier about installing an adjustable proportional valve thiking I had one of those stand alone types however; do you think it is doable to eliminate the valve in the ABS which only controls the rear brakes anyway and plumb a rear brake adjustable proportion valve, or?
It was a technical service bulletin because as many know, the rear brakes on the burbs SUCKED! There's a post here somewhere where they tested the stock valve and found GM capped rear pressure at 600, but started tapering it off alot sooner. The new valve caps rear pressure at 800, but keeps front and rear braking pressure closer for alot longer. The other part of the tsb that applied to all vehicles with the 13x3.5 rear shoes was the new rear shoes with updated friction material. My Burb's brakes were pretty good with just stainless brake lines until I did my swap. After my swap the added weight made stopping scary as it felt like the rears didn't do anything. Replaced the valve and it was a different story, and the rear shoes made it so you could actually feel the rear brakes. Now with the 1 ton drw brakes and 3500hd booster, I can stop if needs be(still kick myself for not going gmt-800 brakes with how often I've had to do my brakes).
So if I call the local stealership (not even the same state the vehicle was previously owned in) with the VIN of my 98 K2500 Burb, should they be able to tell me if it had been replaced with the updated valve under that tsb or not?
