Turbine Doc
Just Another Diesel Guy
I don't much care what its pumping out my Bloody turbo, as long as its no longer pumping it into my air filter then i have fixed the my problem.
The oil consumption has reduced or stopped all together so far so that issue is also fixed.
As for putting a 90 year old on steriods LOL n killing it faster Oh well. . .healthy or sick i am still going to do what i do.
Its not like i am going to rebuild it, So if it splits the crank case wide open. . .oh well. . .I get a new Rig simply put !
This thread wasn't intended for 3 pages of trouble shooting it was just an update stating that i had Fixed the issue from the "OLD 6.5 STRIKES AGAIN" thread and a couple of the mods i did at the same time as well, along with a list a Mods to come.
I am going to do what i have to get it to do what i need it to do if that shorten's its life span or kills it off all together then thats the way the Cookie crumbles i guess. . .
As for the New air filter n New breather they are what they are . . .
Mike
Granted you did not ask for a disscussion or trouble shooting for what is happening with your oil consumption, nor did you lead off with "yes guys I know my engine is consuming oil please don't comment on it"; I would suggest however if you did not want feedback then you might not want to post in a forum that encourages bi-directional exchange of ideas.
Folks (myself included) were expressing their concerns for well being for what you propose as food for thought, but actually when you get down to it we don't really care about your bloody turbo either, since in past you have taken extreme exception to suggestions offered by members in past here.
So with that said; do what you will with your engine, you came here earlier in the year dissin the 6.5, well it is your engine as you are inferring and apparently you don't really care what we have to offer on the matter, so be it.
But do not come here later with a tale of woe how badly your 6.5 treated you/let you down, & when it does decide to finally die on you, you were an active participant in it's demise.
You reported oil consumption, several of us feel you are "band-aiding" it masking the symptoms running thick oil, altering the correct scavenging of the crankcase on a mature engine.
For the other stuff you are thinking of doing, do not waste your money, from what you are reporting of current mechanical condition, this particular engine is not a good candidate for modification for more power.
Those of us who run highly modded high power engines are doing it without excessive oil consumption, or running 60 weight oil, or bypassing the CDR system, if you are having to do any of that to keep your oil consumption down, BEFORE ADDING ANY FURTHER MODS, you had better find out WHAT IS WRONG with this engine.
If you spend money for mods as you plan you'll be disappointed, what you propose will only hasten your engines demise, if you don't want to overhaul it, (if that is what it needs) why would you spend more $$$ into performance adders, that will only be trying to make a silk purse out of a sows ear.
I'm done with this one, recommendations made; your choice to listen to advise or not, fellow 6.5ers, my advise is to let Mike do his own thing and then let us know when it craps out for good.
