- Staff
- #21
Measure the piston diameter. Theres 3 different caliper sizes that look almost the same, but they all use different pads.
Inner pads is a caliper sticking issue, outer pads is an issue with the slides, , , ,
YesWould this be the same for '82 - 3 - 4, PU, Sub, Blazer, (6.2 diesels)??
7200 are the smallest(half ton and light duty 6 lug 2500's), 8600 is in the middle. . ., and the DRW 9,200+ are the biggest.
I'm upgrading to DRW stuff . . .
I ordered new rotors, pads, and calipers all for a 3500 dually of the same year truck. I'll know 100% certain next week, but I see no reason it won't work as all 8 lug trucks all use the same hub bearing and knuckle. Duallys got different brakes and 3.5" wheel spacers, thats the only differences I could find scouring the parts catalogs.For an 8,600# setup, is there any modification necessary when going from 8,600# to 9,200# (aside from caliper and rotor)? Or put another way, aside from the caliper and rotor, what does a dummy like me need to get for the shop?
I got the DRW stuff on tonight, and I can comfirm that the DRW stuff WILL work provided you swap over to all DRW(9200) stuff. The calipers are roughly a 1/4" wider where they go down over the rotor, so you have to use the thicker rotors with them(and the thicker rotors will not work with the SRW/8600 stuff). But I swapped over to the bigger calipers, thicker rotors, and pads, and it all bolted right on. The DRW calipers actually have MORE clamping force than the newer 01-06 HD dual piston calipers do, but they have double the friction area with the massive pads they use. Will know more tommorrow about how well they work. Going to try and do a brake sticky on what swaps to what for others thinking of upgrading.For an 8,600# setup, is there any modification necessary when going from 8,600# to 9,200# (aside from caliper and rotor)? Or put another way, aside from the caliper and rotor, what does a dummy like me need to get for the shop?
What are your thoughts on cryo treating the rotor?
