The way it was explained to me by Bill is that they don't give you 40HP, but rather the ability to be able to give you more fuel to support 40 additional HP. Really if the pop off pressure would be able to be raised then the fuel volume would be increased. On the mechanical pumps you turn them up to add more pressure thus adding more pressure to the injectors and in turn feed more volume of fuel to the chambers. On the other hand the DS4 pump does the same thing but with a re-flash. So with a slight increase of power Heath re-flashes the PCM and it raises the IP delivery pressure to add more fuel. If you wanted more fuel than that the Marine injectors would be needed as they have larger orifices. A GLE would typically use stock injectors while a GL4 would be able to use the extra volume of the marine injectors.
