North Maine
Merchant Mariner
Ok I did search, but it really has never been REALLY clarified, so I'm asking.
Marine injectors/HO Injectors/High Pop Injectors whatever you want to call then every vendor claims will boost power, and the general rule is that they will only boost power if you can supply more fuel, such as with a chip/ECM reflash. This however, does not make sense to me. The way I understand it, lets the say the IP is pumping 60mm^3 of fuel per stroke, wouldnt ALL of that fuel get sprayed thru the injector, regardless of marine nature or HO nature? I don't see how an injector can put more fuel into the engine, which is what makes power. Can someone educate me on this? (I feel dumb now.)
