In theory,
What would be the ultimate block to use, a 6.2 or a 6.5.
It seems to me the 6.5's only crack if it gets over heated.
If I have a 99 block that is crack free would there be any reason not to use it?
Do they crack if you try to run over 300HP or is it just the overheating.
For 18:1 pistons at what temperature do the engines have a hard time starting?
I have the resources to make billet roller rockers for the 6.5. Do you think these would be any advantage over stock since the motors don't rev that much? :smile5:
