just a number
Active Member
I need to change/upgrade the hard drive in the laptop. current setup is with xp. It's only has a 1.6ghz processor and about 1.5 gigs of ram. Right now space is the biggest issue, it's only got a 20gig hdd in it.
so the big question is, which would be better on the reinstall(larger hdd))?
2nd question. It's currently using ide/pata setup but you can get a sata adapter for it. is it worth the extra cash for the sata setup?
