U-Joints
treegump
Romans 3:22-24
Martinsville, IN
(in general - but I'm working to replace my front driveshaft u-joints)
I purchased u-joints from auto zone and 2 caps fit, but the other two (that were perpendicular) were too small for either the shaft yoke or the differential yoke.
Anyone have a part number, or an explanation as to how auto zone can screw something like this up?
The yoke may also be bad and give you a loose fit. You can cheaply replace the yoke. If the proper u-joint has a loose fit issue anyway.
Just bought (2) u-joints from Bumper-to-Bumper (something like $18/ea) : Precision 534G - greaseable w/ retaining clips. All four caps of one (and its the same, so the other 4 ought to be the same) are a snug fit entering the yoke on the driveshaft.
One thing I did forget to do though, I forgot to mark the yokes to match them. :(
iv had alot of troubles buying u joints for the front dshafts of my truck i finally stoped buying them at parts stores and going to a drive shaft shop in town they always get it right and seem to be better quality
U Joints for the K2500 HD (8 bolt axle) are different from K2500 LD (6 bolt) All the parts books I looked at showed the K2500 HD version.
I went through the exact same issue, i bought them took it to my local shop and they were wrong. So i just bit the bullit and had the shop buy the parts and install them. I think their part numbers are f-ed up
When I was looking for front u-joints I got annoyed by the local part stores so I drove to summit and found the right ones :).
