When the timing is set engine hot:
Roll on 45 MPH and hold steady. Should have some diesel rattle. Add throttle. The Rattle should go away as the precups heat up. Advance lowers EGT and less drive pressure for the turbo. Too much advance will erode glow plugs. Too little advance will white smoke cold.
