Goldsburg
Diesel Tinkerer
OK, yes you can increase RPM to increase air flow, same on any engine, and I whole heartedly agree that it is more efficient and better power with the ATT, but it is the same fixed volume when that exhaust port closes. However now you could reach higher RPMs safely and efficiently, because of the lower pressure differential, boost and backpressure both.
If the scavenge process, or exhaust stroke weren't working correctly before at high RPM due to high backpressure, then that might be a way to slightly increase the volume of fresh air in the cylinder, but its not like youre gettting even a 5% increase there, not like you saying it is capable of twice the CFM at the same PSI.
And yes if you maintain lower IATs the air mass is increased, but not flow, same flow but more dense, which is also a bug imporvement. It would be better to just say you get more air mass at lower pressure.
Buddy -
You are on the right track. It is always best to think of a turbo charger in terms of a "mass flow" device. That way, all pertinent variables are taken into account. Further to that point, I never like how people talk about volumetric efficiencies "greater than 100%" when turbo or supercharging. My engineering education just prevents me from accepting that vernacular.
Beyond that, superchargers or turbochargers increase charge density (not volume). A vessel (cylinder) can NEVER be filled greater than 100%, especially when the filling process is being throttled by a poppet valve.
Regards,
