94turbo-
I built a turbo master device for my 94, and I am very happy with the results, and I realize that if driven wrong I will use more fuel, I did build it for pulling power. However, has anyone reduced the boost for economy? My assumption is that you should be able to reduce boost to a certain point (loosing power in the process) increasing MPG, until other factors take over and you loose MPG? If this is the case, how much Increase could you gain? Even better, if a few MPG is achievable, could you build a mechanical cam-spring preloader (like a VW diesel cold start device) to give best of both worlds?
I'd rather have a user selectable chip to control MPG/power, but being a OBD1 I can't seem to find any in that department.
